Is JBL GX-A644SI good enough to drive JBL GTO S649C??
syednizamudeen
Tirunelveli, Tamilnadu
Hi people,
I own a Honda Jazz 2015 E variant, which doesn't come up with a stereo.
I'm eyeing to put up the following setup.
Head Unit : Blaupunkt New Jersey 220 BT
Mains : JBL GTO S649C Component Speakers
Rears : JBL CX62 SI Coax
Amp : JBL GX-A644SI
Will the 6.5 inch speakers fit inside the door pads and will the amp and speakers are good enough on budget??
If there's any other recommendations in this price range please feel forward to drop your valuable comments.
The low end JBL are all lousy . First , you need to tell us what type of sound quality you prefer . If you require smooth sound or laid back sound the JBL would be too harsh
