It's class AB from Nelson Pass
Actually the most logical thing to build after the V2T will be a 40-50 Watt Aleph X
(OM & Sachin ,I know I'm evil :-))
We can reuse the chassis Om can design the 4 fet PCB with same mounting specs as F5T :-)
Well I have built and heard the F5 and Aleph J & like most NP followers me thinks AJ sounds better :-)
Oh boy, I have not even finished F5 V2 and now this shows up. I dont think I have any space left at home.
I forgot to see bold - I am not building it now. If I take another amp job soon after F5T then I would be chased in woods.
Nelson Pass has been designing class AB amplifiers for many years.
Why do you say that? He has always built class A Amps which work in Class AB after certain levels of power. His biasing has been in Class A. This is his first pure Class AB amp.
I always thought an amplifier which works in class AB when it goes beyond its class A power region is supposed to be class AB amplifier and not class A amplifier, i could be wrong.
AFAIK, pass product catalog has always had the X series which are Class AB,XA series which are Class A up to 4 ohms loads, and the new XS series which they say is an improvement over XA.
For example lets say an amplifier works in Class A say till 25 watts but its rated output is 75 watts @ 8 ohm, when this amp is connected to a speaker the power delivery is very dynamic depending upon the speaker efficiency,the music being played and Impedance drop.Considering this fact these Class A design which switches to Class AB wont work in Class A most of the times unless it is a true class A design like the ones made by gryphon and a few other manufacturer where the power doubles in Class A up to .5 ohms.
Again i am not an expert, in fact i know nothing much about how these amplifiers work but this is what i understand from certain people and by reading,if there is a different explanation then do let me know and i shall learn.
