just to clarify
markyboy156
kettering
hi
just to clarify
if i was to use my denon 4400 with 2 emotiva t2 fronts and c2 centre
what can 2 amps can i use to vastly increase the 2 front speakers quality of sound
i want to connect 2 amps to the main denon 4400
to the low frequencies of the main left of each left and right speaker
and then the other amp for the high frequencies of the left and right terminals
what would be the best opions to use
i already have a emotiva xpa2 gen3
what do people advise thanks
then i will use emotiva upa 200 blocks to improve each speaker
i will be using a 11.4 system
hi
just to clarify
I was recently auditioning for stereo amp and when auditioning. I heard the wEmotiva T1 towers and was very impressed. They performed significantly better than Dali Option 6, Zensor 7 towers as well as Fyne audio 303 towers.
I am really interested in finding out what amplifier you settled on to drive your T2 towers because they are 4ohms rated...
