KEF Q Series BS
Vishal
Seeking opinions in SQ, performance and any other relevant feedback on KEF Q300/Q100 BS speakers. Looking to match them with NAD 326BEE (or 356BEE).
C
want to compare them with NAD + PSB.
Where can I audition KEF's in Mumbai?
Vishal
KEF s can be auditioned at ProFX , Atria Mall at Worli. KEF Q300 is a brilliant speakers, pairs very well with NAD326 and Marantz PM600x series Integ amps.
Q300 is really good and most often than not paired with Marantz PM6004/ 7004
The Q300 in particular are bright speakers. So pairing them with a NAD326 should be a very good match as well. Considering your room size which you mentioned in another thread. The Q300's should be sufficient. They are bassy speakers and wont disappoint.
However I do feel you should either freeze on any one component the Amp or Speakers and then carry your equipment and audition everything in your budget
Because at the end of the day what may sound good to you may not sound good to me/others.
Pairing of Speakers + Amp is subjective and depends on the listeners ears where they want a bright / neutral or warm presentation of sound.
- F l a s h -
Good point. However, ideally I'd like to freeze a component, say an Amp without buying it. Very few dealers carry the NAD and I would like to audition the NAD with PSB, Kef and Paradigm before buying the speakers. Seems like I would have to buy the Amp and then carry it around.
I'm just looking at the best/cheapest option to buy the NAD.
