Klipsch Hershey
johny747
Any of our members using these speakers? Heresy, Heresy II & III
What about Klispchorn, LaScala II & Cornwall's?
Would like to listen to your feebacks!
Would an Integrated amp be able to drive these?
:D you made a meal out of the heresy's! calling them hersheys :licklips:
Johny I wanna hear these speakers too!!! Supposed to be the cream of Klispch :licklips:
AFAIK, all of them are High Sensitivity Speakers so you may even run them with low power(tube) amps. Tube amps are supposed to be a very good pairing with Klipsch.
Calling them Hershey in itself is a heresy. Delicious irony!
I've heard some confusing things about Klipsch. Can anyone please clarify? While their speakers are very high sensitivity speakers, they also apparently require a lot of current (their impedance dips quite a bit when reproducing bass heavy music). This would suggest that they will really work well only with a high current capacity amp. On the other hand, a lot of people also say that it should work well with low power amps. Which one is true?
