KV-907 Stereo System Class AB Integrated Amplifier /With Floor Standing Towers
CAPT BAURY
ANDHERI WEST
Guys,
Found Panda Audio amplifier with floor standing towers in Amazon India.
It has got good features like Bluetooth and sing along functions.
I want to use it with my media player (analouge output) and mobile using bluetooth.
Don't know how the sing along function will work and mike connectivity for same.
Wonder where I can audition it AND HOW GOOD THE TOWERS ARE?
Appreciate feedback from members.:clapping:
Below is the link and other specs:
KV-907 Stereo System Class AB Integrated Amplifier: COPPER: Amazon.in: Electronics
STEREO SPEAKER SYSTEM WITH SING ALONG FECILITY KV-907 Stereo System 400 Watts RMS Achieve maximum performance from your stereo components with our flagship speaker system. Only live sounds better. . Stereo Integrated Amplifier Bluetooth connection Floor Standing Front/Main Channel Towers: Low/Mid Frequency Transducer: 6.5" X 4 Nos Silk Dome Tweeters 4" X 2 Nos Enclosure Type : Bass Reflex Dimension W X H X D mm: 225 X 775 X 255 mm Weight : 11 Kg each Sing Along Feature SPECIFICATIONS: OUTOUT POWER (per channel) 8 ohms 20 Hz to 20kHz 0.1% THD, 120 watts RMS . 4 OHMS 1kHz, 0.1% THD, 200 watts RMS DISTORTION SMPTE-IM, less than 0.05% . THD less than 0.1% at rated Power (22Hz-20kHz) Frequency Response 22 Hz to 20kHz, +0/-1 dB, 1 watt Damping Factor Greater than 150 NOISE 100 dB below rated output (A weighted) SENSITIVITY 140 mV (for rated power at 4 ohms) . CD, DVD, AUX Input ,Volume Control at Max VOLTAGE GAIN 39 dB (CD,DVD,AUX Input,Volume at Max INPUT IMPEDENCE 20 K ohms unbalanced Amplifier Protection Full Short Circuit, open circuit, ultrasonic, and . RF Protection LOAD PROTECTION On/off muting and DC - fault protection TOPOLOGY 2 Channel Power Amplifier with Integrated . Tone Control, balance and input selector OUTPUT CIRCUIT TYPE
http://ecx.images-amazon.com/images/I/91e61TVoq-L._SL1500_.jpg[/URL]
Since you are located at Mumbai, you could visit Lamington Road. There is a small shop called Choudhary trading which is the shop for Panda audio gear. They had a listening room at Lamington road, but i wonder if it is still exists.
Regarding the amp you mention, I have no information. I am basically into the listening of Vinyl-stereo gear. Panda audio amps used to fascinate me about 10 years back because of their low price range. I feel you could also check out the availability of your requirement at DNM audio. Mr Dilip Bajaj used to sell some nice stereo amps and speakers about a decade ago.
Norge is another good indian amp but they cater more to stereo for 2 channel audio.
