Looking for 5.1 home theater system
Deepk
Pune , India
Denon 660H (AVR) + ES20 ( L&R) Spkrs + ES35 ( Center Spkr) + ES10 (Satellite Spkrs) + 10" woofer. Please help with the authorized dealer & comparative cost ( India-Pune)
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
Go for Marantz AVR amdnd Taga Harmony Speakers
AVR will be expensive than Denon but cheaper speakers will make the complete package come in your budget.
