Looking for a sub woofer in Mumbai
pushkarDighe
Hi Friends,
I had recently started hunt for a sub and after reading in another thread about velodyne impact 12 decide to check it out at Alliance 4 in Goregaon. But there I heard the connection thump of Eq-max 15 and immediately realised that I found my beast and there is no need to look any further.
15inch speaker, room equalization, remote control and all this for just 45k was too good to be true. Unfortunately I could not buy that day as had some constraints. Two weeks later (yesterday) I was ready to go ahead and gave the dealer call to place the order.
But then the bad news; Eq-max15 has been discontinued with no new model in its place by Velodyne. So I am now back to square one.
Help needed: a sub with similar specifications, same cost range (can stretch if the sub is really worth it) & having a dealer in Mumbai. Suggestions welcomed.
Thanks,
pushkarDighe
