Looking to buy speakers for Pioneer 924
kpatel
India
I have already bought Pioneer VSX 924, now I am looking to buy 5.1 speakers for this receiver. My budget is less than Rs 30,000. I live in a small town so I cannot even go for auditions so I am relying on your suggestions.
Thanks for your reply. I was almost going to finalise buying Boston Acoustics S5.1 but then I heard that the company has stopped manufacturing, so I was sceptical in case something goes wrong with the speakers and I cant repair them.
I really want to buy the Andrew Jones but they are a bit above our budget. Our local store is quoting me Rs 54000 for it. Do you think that's a fair price or that should still go lower?
Hi Patel...
It seems like your receiver is quite powerful. So you can skip the wharfedale and BA which you mentioned above.
Your ANDREW JONES model OK but still you can get more suggestions from FMs..
To match your AVR you can go with Dali zensor or Wharfedale diamond series.
Dont buy the speaker package for the time being now. Think about the future you may need to upgrade it.
