Making of 'MY Double D' guitar distortion
kaushik
Project Log :
Name: My Double D
The Idea :
I wanted to make a decent distortion pedal for my guitar , at a lesser expense .
Also wanted some thing of small foot print.
Online i got good reviews for the Double D . The simple design looked great ,
component count was less and .only 1 chip! CD 4049 ... power packed with six
inverters .
The URL [runoffgroove site]:Double D
Then i checked the sound clips ..online both modes sounded as pretty nice ;).
The kit should not cost more than 180Rs. leaving the cabinet and accessories .
DAY1: Making of 'MY Double D' guitar distortion
DAY 1
12:46 PM 6/26/2008>
[Thursday]
-today is the first day
i just did the shopping[sp road]:confused: .. i hope all components are in stock
components alone< 100Rs i think:)
-getting the J-FETs was a pain ..i replaced the J201 with J 112
-i have laid one white paper on floor, placed the parts ..checked
taken the pictures
-read the runoffgroove.com author's page on my laptop ...the journey begins here ...!
DAY2: Making of 'MY Double D' guitar distortion
9:38 AM 6/27/2008 >
DAY2
yesterday the following were purchased
-Capacitor box , all the reqd pf s , it was lacking some of the reqd values
soo i added the values ..
still some are missing line 47kpf etc ,plan to purchase today ...
-IC CD 4049 , J -FETs j112 [as a replace ment for the J109 ] ,vendor told it should match the
actual one upto 90%
-Ribbon wire 6 core , 1 mtr , for the pots ,
-Mic jack and socket , for testing phase i am using a cheap mic jack 10 Rs and Mic socket :)
-Electorlytics 10uf and 4.7uf ,diodes 1N4007 [for the soldering iron ..heh not part of original double d]
-A cutter and Stripper , to be used wire and leg cutter
-A soap box ...wait its a temporary cabinet to hold the SIX POTS ,and the mic jack ..battery etc what so-ever
- also a thin soap box is :) . easy to drill ... with the mosquito coils ..my new trick
The already exiting parts
- resistor box , still some missing values like 1 M , 2.2 M , 220K etc
soo i have to add today
-solder materials
-hook up wire , wires with one solid strand
-favicol, see below
-Added the components to the board [yellow verro board for a test run]
The disaster ..
My cheap [25 rs] soldering iron died ! :mad:
- so i i just the components are added to the verro board as per the plan in the website ,
This saves time !
- and i used *favicol* to hold them in place as i could not solder the components
[usually after the legs are bent and shortened they tend to fall out and if it happens will be a bigg trouble ]
-finally i was able to visualize how the assembled circuit will look after it is done
to do:
-Buy a good soldering iron , missing parts ,extra solder wires , shielded wires
-then the solder the board
-solder the ribbons to the pots ,fit in the soap box
-test by connecting to the pocket AMP
(...my secret tiny amp ..runs on 9V battery )
-Add a killer looking final cabinet ..keep watching
Day3: Making of 'MY Double D' guitar distortion
9:34 AM 6/29/2008 SUNDAY
DAY3
- Today I finished the assemblibng part and soldered all the components
- Just 2 Pots are conncted as I planned to test JIGGLE section
- A MIC Jack as input and output through a MIC socket
1 st test
- I have connected the unit to the 9v battery
- connected my guitar and MINI AMP from the out put
- "No sounds" !!! meaning 1 st test failed
I have made a list of tests to diagnose the problem
suspects > 1. DRY JOINTS ,My solder wire was very poor , all the time some coating settled n the Iron..i had to remove
that coat so as to make the soldering come in contact with the solder wire ...otherwise it does not melt '
2.MAY BE THE IC DIED : IC CD 4049 is a CMOS device..sensitive to temperature ... as i did lott of soldering in the past
i avoided to use a IC base ... may be during the asembly the IC died
3. May be the Supply, MIC connections ,OUT put connections
Diagnosis
- Tested the FETs by isolating and applying +ve gate voltage using 100K resistor ,a test LED comnected between Source and Gnd.
As i apply the +ve bias the LED glows bright ... soo FETs are alive !
- Visually checked the IC connections ....all ok ..
-Next I will do some electrical checks...:)...
notes:i have taken the pics ... my phone cable is missing soo assume "PICS COMING SOON .."
wanted : comments comments .. please
'MY Double D' guitar distortion in pictures so far
Tools and solder side
Here is ......
LIST]
>MY SOLDRON
>COMPONENTS SO FAR ASSEMBLED
>THE PARTS -GALLERY
[/LIST]
you can see the soldron logo ....not burnt up after heating [means original :D ]
... parts including 2 pin connectors to make life easy ....
..i have kept some space between different circuit [ like the pre-boost ,inverters and post-mixer] sections so as to easily examine each one section in case of problems ...:)
....any suggestions??
great project. keep posting pics and details man. would love to see how it comes through. i might wanna try making one. also have you tried amp and effect modelling software?
keep up the great work!!
k
