Marantz 1506 for wharfedale diamond 10.6
kaushik_dhume
goa
Will marantz 1506 be able to power wharfedale diamond 10.6 if I don't like to play my music too loud ?.my area would be around 220 sq ft
I heard NR1506 on Polk Rti A5 on stereo.The sound was amazing.Really enjoyed music on the pure direct mode.
Since it is the starting model for marantz av receiver doea that mean that I have to play the music on lower volumes only or could I play it reasonably loud. (Not full blast ofcourse)
I used the NR series for more than two years in an area of 250sq ft and never had the need to crank up the volume.....to enjoy optimal performance, ensure that appropriate speaker wires (OFC), HDMI cables, good high quality media content (MP3s/Blu Ray, etc.) is being used....
Besides the Audyssey calibration setup which in most cases can derive skewed outputs, you can manually adjust the speaker levels, including source levels...not forgetting the Bass + Treble settings along with 9 band manual EQ adjustment for each channel....refer to the manual for details on how to do these settings....advanced settings....
Thank you for your invaluable inputs.
I am using Marantz 1504 with Polk TSi 200 front and Polk Monitor30 rear. Marantz are usually warm sounding and Polk are considered bright. For me the combination works great for Movies and decent enough for Music too.
Thank you .I am goin in for marantz r 1506/with wharfedale diamond 10.6
Thanks a lot.
Sent from my MotoG3 using Tapatalk
