Marantz In Ear Earphones
abhi_104
Friends,
Can anyone rate the Marantz HP101 Aluminum In Ear earphone
How much do they cost & hows the sound quality?
Specifications (Downloaded from net):
? Frequency response: 20Hz ~ 20kHz
? Nominal impedance: 16?
? Sensitivity: 98dB/mW
? Power handling: 40mW
yes one of my colleagues has it - he picked them up from besybuy I think for 60-70 USD from the US a couple of months back. I had a chance to listen to them for an hour during a flight - and I can give you some initial observations.
1. they have a decent build quality and are lookers.
2. midrange is recessed so are the highs - prominent bass though attack and decay is spot on
3. sound stage is small - non existent mostly
4. sound isolation is average - the engine noise did creep in a lil bit
If you are getting it for 2-2.5k, you can go for it else there are other options available in the market. The re0 is guess is a cheap yet pretty good IEM. I use the Beta Brainwavz these days and for 1.6 for it (with the e5amp) i think nothing under the 3-4k segment comes close to it.
Over 5k there are good IEMs available though.
