MARANTZ SR 7008 with Tannoy DCT6SE
vsvasan
CHENNAI
Recently Purchased Marantz AV Receiver SR 7008 and Tannoy Floor Standing Speakers DCT6SE.Marantz Receiver is matching well with Tannoy Speakers and the combo sounds excellant
Congrats buddy... Plz post pics of your setup.... How much did you spend ?:)
Congrats. These were the speakers I was chasing until I came across the Monitor Golds.
Spent around RS.2.2 Lakhs.
Shall post pics soon
Marantz SR 7008,Tannoy DCT6SE,Rotel RA-12,Monitor Audio M6,Oppo BDP-95,Pioneer LX-55,Marantz CD 6004,SVS PB 12 NSD,Asus mini O play,Seagat HDD 2 TB,Airtel DTH,Chord Crimson RCA,QED Optical & Audio Quest Type-4
Distributor for Tannoy : Acoustic Arts,Delhi (Purchased Through Bangalore Dealer Music Ranch)
Initial Observations on Marantz - Tannoy Set-up :
DC6TSE has 90 dB sensitivity with 8 Ohm impedance and SR 7008 is driving these speakers quite easily
High Frequency : Able to deliver HF signals without harshness
Low Frequency : Just Adequate Bass is delivered (Speakers have been operated for only about 150 hours and expect that,the Bass effect may change after few months of operation)
Mid : Clear
Can hear musical Instruments separation and vocal clearly.Overall very satisfied with the performance.
Posted Picture.Resolution may not be perfect
Sir. U can try keeping the sub in right corner. By moving the audio rig little front . Try experimenting the right place ur. Sub will do more justice than this. One more suggestion. Try to increase the space between two fronts. Try to center the tv in the wall If possible.
+1 to that. The towers look too close to each other - increase the distance between them. What is the distance to your listening position. Try to make an equilateral triangle of your listening position and the two towers.
Also please read the various write ups on sub positioning. Though I do not own a sub but various members have vouched for the crawling method as the best way to determine the position of the sub.
