An interesting experiment which actually measures the quantum of improvements with & without using a pair of audioquest wind RCA "PSS silver" cables.
The competing cable in this is also a high quality cable though might not cost much.An interesting experiment which actually measures the quantum of improvements with & without using a pair of audioquest wind RCA "PSS silver" cables.
6. His measurement equipment is not resolving enough to determine the difference in cables.
Ah, yes! Sorry about that.Proper knowledge and application is needed to do it right.
Absolutely correct, sir! Just don't forget to cryo treat them cables, though.If our expectations are properly managed there will be fewer disappointments.
<snip>
Nobody is absolutely right or wrong.
There is a difference between going for the absolute perfectly measured thing and liking some pattern of non perfection subjectively. The whole Hi-Fi industry is about the non perfection. Otherwise studio gear already is brutally truthful. For example. If one claims someone hears more detail on his gear more, they are only hearing those thing that their system exaggerates which is in turn an imperfection. I recently sold my bowers and Wilkins P7 headphones. They just had so much more detail in upper mids only because they had peaks their on their graph compared to a hd 600 which is rather flat. But that peak also means it had wrong tone with many instruments. It was like listening everything through a horn! But for a. Non technical person it would be better headphone than the hd 600. Similarly if understand the concept critical bands / masking in freq and time domain well, then with a parametric eq you can alter the sound of a speaker (a studio monitor, preferably) to have wide soundstage, lush mids and any other sort of subjective quality they are known for. If you look deeper into every graph and look where the dips and highs are in respect to critical bands, you always get the answer why a speaker sounds wide, or airy or thin or so.If measurements were everything, there would have been no need for this forum. Science only helps to understand nature, not define nature.
I have Come up with Few New Of Mine, All rights Reserved!Before someone else says it, let me beat them to it:
1. Science has not yet learnt to measure all that needs to be measured which affects sound. For example, how does one measure timbre?
2. Measurements are meaningless.
3. Forget fancy graphs and measurements. You do not listen to squiggly lines do you?
4. Music must touch the heart. And the soul. It should move you even if it is jarring. And it will if you buy this. And nothing else matters.
5. Silver cables are bright sounding in my system. Because silver is shiny, shiny! Also, they should be stranded. In the jungle!
6. His measuring equipment is not resolving enough to determine the difference in cables.
7. His measuring equipment is using the stock power cord. He will at least hear the noise floor drop if he uses aftermarket power cords.
Additions are invited.
ASR is a nice read, but basing everything on squiggles, as @keith_correa rightly puts it, is a one dimensional approach.
[...]To be continued....
7. My DIY IEC cable socket broke last week when I tried a 12 awg X 3 stranded silver cable. Since then I am using a stock computer cable connecting my amplifier. That sucks and am unable to listen music for more than 15 minutes. Today am taking half day leave from office to just buy the damn IEC socket.Before someone else says it, let me beat them to it:
Actually there is only one dimension to define the sound of a System which involves several parameters. Every sound profile is a combination of these varying elements. But it requires much more knowledge about how it relates to sound profile than the training earsI think you'll find that Keith's response (in its entirety) was sarcastic.
