Murphy Manor Tao 747
zero7
Today I switched on an old Murphy Manor TAO 747 from my dad's collection. It's physical condition is pretty good. It produced hum and made a sparking sound and immediately I turned it off. After a minute powered it up again and same sound came, as I was observing itt, that was coming from the electrolytic capacitor from power supply section. It's 50 Mfd, 300V.
Where can I get it or can I replace with a newer one? Appreciate any suggestion. I guess that's the first step to fix this radio. From the picture, you can see the leakage and rusting of the chassis as well.
(unable to upload the pic. Need to compress it. Will upload later)
Got schematic and guidance from FM, Mr. Venkat, who has same model. Will try it out and post the results in couple of weeks. (need to go and get 47uF caps to replace)
Due to the pandemic situation haven't been able to go out and get few more parts. Need some caps and resistors. And unable to find the value of the part in the pic below. IMG_20210411_160059__01__01.jpg
HI there, I am trying to restore a Murphy TAO 747; do you have any documentation on the circuit dia or schematic that you can share.
I am Uday Kalburgi, Here is the schematic. Be sure you replace all old capacitors, ensure the Filter capacitors are within limit of the rectifier valve.
Please find the schematics that I have. I couldn't get clear schematics which are readable. Hope this helps to some extent. I was told that the schematic of Tao 776 is same as Tao 747.
Sir, attachment didn't get posted I guess. Do you have a clear schematic than the one I attached above?
it is 6mb, give me your email id, I will mail it to you, or whatsapp connect.
Uday K
9845043014
Thank you sir. I have sent you my email ID in WhatsApp
Thanks to @udaykalburgi. Received the clear schematic diagram from him. Will work on the radio this weekend, hopefully.
Sharing the circuit diagram received from Mr. Uday Kalburgi. Credit goes to him for providing a very clear circuit diagram.
Thanks a lot; i also got the version from Uday
Thanks for the advice; will change caps; also looks like i
1. Might have to change all the valves; 1. Any idea where i can get a complete set;
2. Most of the resistors are 1W; are there any resistors on the circuit which are higher than 1W; as that detail i don't find on the schematics.
Thanks in advance
