Music Hall - CD-25.2 CD Player
vijayk
Pune
Has anyone here owns Music Hall - CD-25.2 CD Player?
I want hear first hand experience... or quick comparison e.g.
Compare to budget Marantz CD63 or NAD 542
Or equitant to Music Hall as Im not sure about other models
Thanks,
~VijayK
Thanks,
~VijayK
If/when you audition, please ensure that you check the levels, the music halls have a high output. One of my customers had a problem as the output (at peaks was distorting)
cheers
odyssey
Thanks for your inputs...
well I have planed home audition tomorrow with my existing setup which is:
- NAD 325BEE
- Monitor Audio BR4
- Sommer inter connecters and Sommer power cable
Now what should I take care during this audition and how do I really check the levels that you mentioned?
Also the quote I received for this CDP is 27K, this is first attraction I have towards it. I found the listed MRP is about $599 in USA
Thanks,
~VijayK
