- Joined
- Sep 23, 2007
- Messages
- 3,658
- Points
- 0
Months back I asked about Cheap Dacs..
Now around 3 weeks back I found it much cheaper on Ebay us... It was claimed to be "just opened" and seller did not find " what he was looking for"
Now instead of US$ 115 I found US$ 76 much cheaper ,and there was someone who carried it for me!
Now I received the DAC ,I am showing you the pictures..
Audio review I'll post after some time as I used it only for couple of hours ,that too in headphones ...anyway I found the sound is fuller - better for MP3s too!
Note that photoes are from ebay ,but mine is too scratch less condition. I really liked the front plate.
Ebay Link
USB DAC (PCM2707+DIR9001+PCM1793) + Headphone Amplifier - eBay (item 170376872835 end time Sep-27-09 09:16:50 PDT)
Specifications from E-Bay................
Nichicon capacity, RIFA capacity, KOA resistors, NEC relay
USB controller: Burr-Brown PCM2707
--Full speed transciever (REAL AUDIO 1.1)
--32KHz~48KHz/16BIT DELTA-SIGMA STEREO
Digital input receiver DIR9001
--The receiver used is more expensive and of better quality than the popular CS8412/4/6
used in all other DACs. It has many more music details and accurate sound you obtain.
Main DAC: Burr-Brown PCM1793
--24-Bit 192kHz Sampling Advanced Segment Audio Stereo DAC
--Dynamic Range: 113 dB THD+N: 0.001%
--8 Oversampling Digital Filter
OPAMP: Burr-Brown OPA2134
HeadPhone: Burr-Brown OPA2604+BC550*2+BC560*2 (Reference SOLO HeadPhone Amplifier)
Such as double side gold coat PCB with high quality soldering.
Technical Specifications
Hardware Features
Digital Input USB X 1
S/PDIF X 1
Analog Input Analog Stereo RCA X 1
Analog Output Analog Stereo RAC X 1
Analog 1/4" Stereo X 1
Power DC 12 ~ 18V 500mA
Dimensions 160*130*48 (mm)
Weight 0.760kg
Audio Performance
Digital Input Impedance on Coaxial input 75 Ohms
Line output 2Vrms
THD 0.01%
Headphone Amplifier output P-Pmax:10V
Headphone Amplifier output THD 0.05%
Suitable Headphone Impedance 32 ohm---600 ohm
Frequency Response 10Hz---20KHz (-1dB)
Ebay Link
Hardware Features
S/PDIF X 1
Weight 0.760kg
Audio Performance
Line output 2Vrms
THD 0.01%
