Need a 10 meter cable which can do 4K@60Hz
deepakvrao
I have read that only a HDMI 2.1 can do this, and they dont go longer than 4 meters? What do home theatre users use to connect to their projectors? Should I get a fiber optic HDMI cable?
Also, is Display port out better or the HDMI port out better? Does Display port out also carry audio?
Fibre optic is better but not a deal breaker. You can go through similar requirements by me. I am happy with the quality offered by the Bluerigger HDMi cable. Will be posting further details soon on that thread.
The display HDMI port of my PC is used as the output and carries audio and video signals together.
Optical is the only reliable option for long distances. You can also get Amazon basics optical HDMI for a very reasonable price. It’s working for me from past 2 years with out any issues.
AmazonBasics High-Speed Fiber Optic HDMI Cable (18 Gpbs - 4k/60Hz), Supports Ethernet, 3D, 4K and ARC - 30-Foot Black, Grey https://amzn.eu/d/7UBaKOe
If you are looking for HDMI 2.1 and HDR and all those Hi-Res stuff, please go ahead with Bullet Train HDMI cable. You can procure it from Audioco.
