Need a suggestion on static sound in the speaker
Rajash B
Hi friends,
Can anyone help me understand the reason for static sound in the speaker . One speaker doesn't make static sound when volume is increased without playing an audio but the other speaker makes little sound. I called an electrician to check the earthing, he found no issues in the earthing, I have installed stabiliser for complete home except AH . I need an advise on how to fix this issue or I would like to understand If this is a normal behaviour with all the speakers ?
Rajash
What is your setup?
1. If you have multiple audio sources as input to Amp/Receiver, try to find which input causes static noise.
2. If it is not input specific, try changing Left and Right speaker connection at Amp/Receiver to identify whether it is Speaker specific.
3. If it is not speaker specific, always on one speaker out from Amp/Speaker, our experienced FMs can help you on fixing at Amp/Receiver side.
