sdhameshia
hello experts,
I have just bought a LED TV(40PFL5059), using it with Airtel HD.
Am planning to buy/build a home theater with it. My budget is very low, 15k-20k max.
My main use will be downloaded HD movies(not from expensive bluerays
) , HD Sports channels, and music.
Am looking for a Home Theater with Digital Audio IN, many entry level systems doesn't have it. It will be used for connecting Airtel DTH with 5.1 speakers, not RCA stereo.
BlueRay player isn't must, but if Player can play all downloaded HD movies then it's good. Mosts don't play MPEG-4 AVC(.mkv). Otherwise I will need to play it on my laptop and then stream it on TV through HDMI. Sound can be converted using HDMI to Digital Out converter.
I know I won't have many options in this budget, still trying my luck. Too temped to buy an entry level AV Receiver(Pioneer VSX-523-K) but it goes out of budget with speakers.
Any review on this?:
http://www.samsung.com/in/consumer/tv-audio-video/home-theatre/home-theatre-system/HT-F4500/XL
this is really tempting:
http://in.yamaha.com/en/products/audio-visual/hometheater-systems/home-theater-package/yht-196_g/
thanks in advance!
thanks in advance!
