need help in getting sub to play along with polk speakers
Sunny1369
USA
Hi All,
I bought polk 5 rm97 satelitte speakers from USA. Now i want to buy a subwoofer to combine with these speakers. Can any one suggest good subwoofer that can fit perfectly for these speakers.
You can buy any sub irrespective of what satellite speakers you have. There is no criteria of matching Sub with speakers.
The typical frequency range of human hearing is between 20-20,000Hz. A good sub should be able to reproduce most of the frequencies within this range. For 100% music floorstanding speakers can deliver good bass response and adding a Sub will give u a deep bass.
Velodyne Impact
Velodyne CHT series
If you want a cheaper option then Boston Acoustics CS 10.
i got jbl es250pw sub & initially i feel it would hear owerpower than my polk rm 6750 satellites but it was very good & there were no disapoointment/issues with the integration part. I am very happy with it. It wins comparing it with any polk sub :)
Wharfedale SW150
Velodyne Impact
Polk Audio PSW
All the above are very good subwoofers, depends on your budget. If you want to spend 40k or more then you have more options.
I dont want to spend more than 6k or 7k on subwoofers. Please suggest me any good brand in this price range.
