Need help in speakers calibration
One person helped me to install speakers and done calibration... But am not happy with his work.I didn't try YPAO
Since you aren't anyways happy with the present calibration done, i would suggest you to run the YPAO automatic calibration by yourself.. Once it is done, check if you like it.. If so, you are done..
If you don't like the above, try overriding the calibration settings value by engaging the pure audio / direct / straight mode on the AVR.. This should override the EQ settings.. Check if you like this..
If you are not convinced in any of the above two approaches, you may scout for profession help..
