Need help to buy CEILING SPEAKERS
manideepk
A.P
Guys, i would like to buy 5.1 ceiling speakers
Can any one pls suggest me the best brands in that segment. my budget is around 10-20k...
Thanks for evry 1
:signthankspin:
At this budget, simply pick up ceiling speakers from Philips and install them. If you looking at a good brand, you will be looking at 10-20K for each speaker.
do u mean the wall mounted small cube speakers...?
if so check out boston acoustics soundware xs. nice good lookign speakers comes for 25k with a sub.
pair it with a 5.1 receiver and you are good to go.
Thanks for evry 1
:signthankspin:
I am just curious as to what would the ceiling speakers would be for. I remember in 80's (i was a youngling then), they were a big fad :).
You might want to think about wall speakers if you just want concealed speakers. It might just sound strange with voices and sounds coming from the ceiling...
daZoy
Thanks evry 1 for the reply ..
my room size is around 23 ft x 15 ft
so which speakers are best for it...which one is best. Is it wall mounted speakers or ceiling speakers to listen to music.
How much should i put for ceiling speakers(the ones that are round and fitted into roof and the wires are concealed)
