Hi guys!
need some help
Been thinking of putting a system together for a bit now. I read up a bit wanted to know your opinion on topping tp20 tripath with ca 30s. my budget is 15000-20000. I read up about the norge 2060 plus wd 9.2 too. is it significantly better than the first combination cause it will be more expensive for sure. also since ill be playing music from my ipod or laptop do i need a usb dac? as for the moment i am not considering buying a cdp
music is mostly dave mattewish/jazz no hard rock, and its a small dining drawing area
also any place in delhi where i can get a demo?
thank you
i was earlier thinking of AE 5,s before but this seems more exciting !
need some help
thank you
