jayantadak
All of a sudden, I found that none of the video files nor the audio files are working when played through my WDTV. The wdtv player shows both the led icons. The interface also comes up. But when I select the file to be played, a circular ring comes on the screen and circles endlessly. Usually the circular ring stops after say 3 seconds and the file should play. But no files play, only the circular ring goes on and on. Any solutions? What might have been happened? I am using 500 GB Wd external hard disc.
Thanks and regards
JAYANT
Thanks and regards
JAYANT
