Onkyo 3400
sarvan
coimbatore
Hi Friends,
Can Onkyo 3400 with its combo speakers is the best buy? Or can I buy some other speakers to go with Onkyo 3400 Receiver. Thanks
You can buy with the same combination speakers, which will be good for HT use, but if you want good quality music, or ultimate quality sound you will have to upgrade all the speakers 1 by 1. I also did the same, i retained the center and surrounds and upgraded the main and sub. It completely rocks, you can check my set up @ showcase your HT thread.
