Optimum RCA Analog Audio Interconnects.
aventhu
My Thoughts
Hi Guys,
Please suggest which brand (model & series) RCA Analog Audio Interconnects would be optimum for connecting Emotiva UMC-1 Pre/Pro with Yamaha RX-Z9 / DSP-Z9 via 7.1 Multi Channel Analog In/Outs. My budget is around INR 10000.00 for 8 (7.1) Cables. Also what are the main points I should consider before buying these cable to get a high end & lossless audio quality.
Budget can be flexible if justified.
Thanx & Cheers :)
Check at hifimart if you have not already. You can different combinations based on your budget. I am using DAC cables and satisfied with it.
Go for Chord Crmison plus. They are very good ICs for the price. It should be close if not same as your budget.
Thanx. I googled. Many say there is no need to spend tooo much on ICs. How would DAC ones perform?
They have two options: One is for Rs.1250.00/pair (9mm thick)
Second is Twisted Pair for Rs. 2500.00/pair. (8mm thick)
What is the difference? Any ideas?
I just don't want to waste money if the job is well done in Rs. 5k.
