Panasonic MIC Capsules in India?
Indus
Hi All
I was wondering if anyone knows whether the Panasonic MIC Capsules like the WM-60 etc are available in India for basic Driver Response Measurements and X-over design.
The Behringer ECM8000 is available though for some 4500/- grand, but I find that a little steep for a one-off DIY Project.
@Cranky
Sasmit was of no help. Panny Distributor in Cal... Hmm. With what mic do you measure Cranky? Could you point to any other mics capsules that could be used with accuracy?
@Cranky
my apologies if I am holding up your project Indus but I really haven't had the time to visit the guy...but the first line in google if you search for WM-60 shows " discontinued " :o
