Panasonic PT AX200u .. is it still good buy ??
Spidey
India
hi folks
getting a "good" deal on this 720p projector,
whats ur opinion ??
what should be a good price in used market ?
other option i am getting :
New Acer PH530 Projector (HDMI port)
how about it ??
thanks
hi folks
whats ur opinion ??
how about it ??
thanks
according to art the PH530 is rated slightly below of the HD70(HD65) The Affordable Acer PH530: Home Theater Projector Review - Summary, Pros and Cons
but a new PH530 is better than a used ax200 IMO, unless u are buying the ax200 from a trusted source and know the no of hrs run in on the lamp..
as suggested by ashish 20-25k for the ax200 and 30-35k for the new PH530..
in the 40-45k bracket u can have a HD65..
I am a proud owner of panasonic ax 200 fr more than 18 months.lamp has run more than 1100 hours!its still goin very strong.If u want flexibility n easy installation,no other proj comes close to the ax-200.HD videos n blu-ray r amazing,better than most theatre screens.i wont advice buyin a used one, unless lamp runtime is less.its very reliable,no probs till nw. the proj has seen 10 hrs continuous runnin, frequent powercuts,etc.til today nt a single prob.
cant comment on ur other options as am nt familiar with em
In that budget if possible u can get a new Optoma HD 65 from abroad which is an awesome projector in under 30k budget.
Personally i have got Optoma HD20 which is the next full HD model
i got mine in grey market -brand new for 60k-aug 2008.i was told ax 3000-1080p wont mak big diff frm ax 200-720p,unless u r watchin frm a long distance.
I am sorry to say, who ever told you that, either does not know the abc of Home Theater, or simply had a vested interest in promoting the AX200. On a small screen tv, the difference between 1080p & 720p is negligible, but on a projected screen anything larger than 60", there is a big difference and the this becomes even more noticeable as the screen size gets larger or your viewing distance gets smaller.
PS: The larger the distance, the lesser the impact of resolution on the overall picture quality..
I have the 200 and I do not like it for the way it flickers. I have never put it on eco mode, and had a discussion too with Ashish to ensure the same. But it hasn't helped. Maybe it gets resolved some day.
Unfortunately this is bad news as flickering is a known issue and has been discussed in many forums including ours, but not all units exhibit this. Try using it on normal mode for couple of hours , it may resolve the issue
I also came accross this flickering problem once with my Projector, and after discussing with Anant about it, I read somewhere on a Forum that I should switch my Lamp mode to the normal operation mode than the Eco, so in my case after following the above instructions my problem was solved, and now I am using it again with the Eco mode and without the flickering problem.
