Panasonic SC-HT895 Multi Region Code Free Home Theater System - Sale
Sculptor
India
Panasonic SC-HT895 Multi-Region Home Theater for sell. Interested? Get in touch with me soon.
Key Features
  • Plays All-Region DVDs: Region 1, 2, 3, 4, 5, 6, 0
  • Plays PAL and NTSC Region DVDs on all PAL or MULTI-SYSTEM
  • TV
  • 6800W (PMPO)/850W (RMS)
  • HDMI Easy Connection
  • HDAVI Control
  • HDMI Up-Conversion
  • HD Enhancer
  • Wall-Mountable 4 Tower Speakers
  • Powerful 6800W (PMPO)/850W (RMS) Output & High-Quality Sound
  • 360 Sound
  • Surround Enhancer
  • H.Bass
  • Music Port for Easy Connection with Portable Audio Player
Perfect with Panasonic Plasma TV -- Features HDMI Easy Connection, HDAVI Control, HDMI Up-Conversion & HD Enhancer, and Wall- Mountable 4 Tower Speakers
Remember all the things you had to do with your old home theater system before you could actually watch a movie? First you had to turn on the TV, then the Home Theater System. After that, you had to change the Home Theater System input selector, switch the TVs input mode, and then press the Play button. Even after all that you still had to get the remote control to hit a few more buttons. That was yesterday. HDAVI Control is today. With an all-HDAVI Control Home Theater System, watching a movie is easy as a single touch. Pressing a single button on the remote control turns on the TV and Home Theater System, displays the playback image, mutes the TV sound, and outputs the sound from the Home Theater System. Its all done instantly, automatically. All you have to do is sit back and watch. Experience this kind of convenience, you'll never want to go back to
yesterday.
Movie theaters create a superb acoustic environment by strategically positioning a number of large speakers around the theater. Due to space and design considerations in our homes, however, home theater systems are generally limited to around six slim, compact speakers. The challenge is
how to use these speakers to create the same kind of ambience you enjoy in a movie theater. Our answer: the 360o Sound. Bringing together three separate functions -- 360Sound, Surround Enhancer, and H.Bass -- this sound technology delivers dynamic audio reproduction with outstanding acoustic motion and wraparound surround sound. The 360Sound delivers a
pure, beautiful, and powerful sound that transports you right into the scene on the big screen.
360 Sound
Drawing from its long history of developing innovative audio technologies, Panasonic has achieved a level of sound reproduction that enhances the sense of motion and space. Sounds move vertically and horizontally across a wide acoustic field, to virtually pull the listener into the excitement and
drama of each movie.
Surround Enhancer In conventional 5.1-channel systems, the sound tends to weaken at the sides or rear of the central listening position. Surround Enhancer projects "virtual" speakers into those areas to complete the circle of sound and enhance the wraparound effect. The result is a full surround sound with the same lifelike, exciting effect as the multi-speaker systems in movie theaters.
Specifications:
  • Playable Discs
  • DVD-Audio Yes
  • DVD-Video Yes
  • DVD-RAM Yes
  • DVD-RW Yes
  • DVD-R Yes
  • DVD-R(DL) Yes
  • +R Yes
  • +R(DL) Yes
  • +RW Yes
  • SVCD Yes
  • Video CD Yes
  • CD--COMMA-- CD-R / RW Yes
  • HighMAT (level 2) Yes
  • WMA Yes
  • MP3 Yes
  • JPEG Yes
  • HDCD Yes
  • MPEG4 Yes
  • DivX Yes
  • Television Signal System PAL 625/50, PAL 525/60, NTSC
Receiver
  • PMPO Power Output
- Total Power 6800 W​
  • RMS Power Output
- Total Power 850 W
- Front 100W x 2 (1kHz, 3ohms, 10% THD)
- Centre 225W (1kHz, 6ohms, 10% THD)
- Surround 100W x 2 (1kHz, 3ohms, 10% THD)
- Subwoofer 225W (100Hz, 6ohms, 10% THD)​
  • 360 Sound Yes
  • Surround Enhancer Yes
  • H.Bass Sound Yes
  • Center Focus Yes
  • S. F. C. yes (7 preset)
  • KARAOKE Functions Yes
  • Rear Wireless No
  • Digital Synthesizer Tuner Yes
  • Weight [kg] 3.35
  • Dimensions [mm]
- Width 430.0
- Height 60.0
- Depth 354.0​
DVD/CD
  • Dolby Digital Decoder Yes
  • Dolby Pro Logic II Yes
  • DTS Decoder Yes
  • Audio D/A Converter 192kHz/ 24-bit
  • HD UP-Conversion/HD Enhancer Yes
  • Progressive Scan (PAL/NTSC) Yes
  • Depth Enhancer Yes
  • Monitor Selector Yes
  • Cinema Mode Yes
  • Dialogue Enhancer Yes
  • Variable Zoom Yes
  • Video D/A Converter 108MHz/12-bit
  • Input / Output
  • HDMI Terminal Yes
  • Scart Terminal No
  • DV Input No
  • Component Video Out Yes
  • S-Video Out Yes
  • Video Out Yes
  • Music Port Yes
  • Audio Input Yes
  • Front Speaker
  • Configuration Full range, 1-speaker, Bass-reflex
  • Full range 6.5cm cone type
  • Weight [kg] 3.7
  • Dimensions [mm]
- Width 252.0
- Height 1123.0
- Depth 234.0​
Centre Speaker
  • Configuration Full range, 2-speaker, Bass-reflex
  • Full range 6.5cm cone type x 2
  • Weight [kg] 1.25
  • Dimensions [mm] Width 270.0
- Height 92.0
- Depth 95.4​
Surround Speaker
  • Weight [kg] 3.7
  • Dimensions [mm]
- Width 252.0
- Height 1123.0
- Depth 234.0​
Subwoofer Speaker
  • Configuration Bass-reflex
  • Woofer 16cm cone type
  • Weight [kg] 4.0
- Dimensions [mm]
- Width 183.0
- Height 396.0
- Depth 267.0​
H.Bass
Dramatically improved audio characteristics in the subwoofer result in ultra robust bass sounds that add to the dynamism and atmosphere of movie and music audio reproduction. Enjoy powerful bass sounds rivaling those of the most advanced theater systems, right in the comfort of your own home.
