Place to buy speaker mount/stands in Bangalore
Sandesh
Can any one suggest where I can buy speaker mounts/stands in Bangalore at a reasonable budget. I am open to customized ones also (wood or metal). Thanks in advance!
It would be better if you just built a pair for your self. Off the shelf, I am not sure if there are many options. Online you can check Tanotis, Sound Foundations, etc.
MaSh
