Harley
Hello friends,
I am planning for 5.1 HT setup in my living room. I need your help with placement of front Speakers, Sub and AVR. I am in the process of getting the interior of my house painted. The electrical work was completed last week and painting will start in few days. So i want to finalize SUB, Speaker and AVR placement as i want to conceal all the wires before painting is done. I am planning to use a flexible pipe through which speaker cables can pass...is this the right way? or is there a better way to hide the cables?. The room size is 14"X9".
Below is the pic of my living room....i have used mspaint to indicate my desired placement of all the components expect the two rear side speakers which will be mounted on the side wall above 3 feet from the listening position. I am a noob at this so need your advice before i finalize everything.
waiting for your suggestions...
Thanks & Regards,
Harley
P.S. I know my drawing is pathetic![Stick Out Tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
Thanks & Regards,
Harley
