please clear one question??
manu4panjab
in my house..,
brothers today i have tried crawl technique for subwoofer placement(as it is my first time ever with this kind of technique) and i found that my sub sounds great(better than its older position) on back wall at right side with 2feet from side wall space and now my question is as i have only done bass traps on front wall corners is there any change in bass sound now as very liitle bass trap is on back wall corners ( only one bass trap on back wall to ceiling corner),please reply i'm waiting
manu,
bass traps are meant for all the corners in a room. it should be from floor to ceiling level.
I hope it helps.
Never make a room accoustically dead, that's the least we can do to kill the sound quality, bad practice actually. SQ in a dead room is boring, lifeless, flat.
A good listening room/HT should have some reflections for a more enjoyable listen.
thanks bhai can we carpert whole floor or not does it make room dead
+1 to what qoolss, vinod_david said , as shown in the picture below
The source end of the room should generally have a greater amount of absorption materials to minimize the powerful and harmful early reflections that color/distort the direct sound from the monitors/front speakers. And there should be less absorption materials at the receive end/rear end of the room creates a live-end that retains the rooms natural ambiance.
got it and what about ceiling do we use diffusers or absorption panel
-- Off topic --
Can you please name your threads meaningfully so that ones who are interested and have knowledge only can view the thread and give comments?
-- Off topic --
Year that's a good suggestion. Infact, I suggest to the moderator that he categorise all threads under certain groups.
