Please help in processor selection
rise
mumbai
I'm about to avail of the xmas sale and purchase an Emotiva XPA-5.
Was about to get the UMC-1 processor with it but I am wondering if it is the best choice.
The reason for this is :
1. I would like a front input as I often listen to music of my computer using a traktor soundcard and most flac or wav files....
I would like to have airplay functionality....
Therefore I am wondering if should get the UMC-1 and then buy a separate networked CD player or DAC to do the rest...
such as Marantz UK | Network Audio Player
Or if I should ditch the UMC -1 and get a marantz or other processor that has airplay and front inputs....already incorporated.
For starters would there be a difference in SQ between using a Emotiva vs Marantx pre?
How well do Emotiva amps stack up against stratos?
Has anyone heard Emotiva with Dynaudios?
If you are referring to the Odyssey Stratos with the Emotiva - please....
if you are looking for HT application, emotiva may provide a better value
cheers
Check out the Marantz AV7005. I think it covers all the bases, and is very nice sounding.
Thanks for the suggestion Viki. It does seem like the AV 7005 would be a better option. For 2 times more however....so I'd have to consider that. One other thread mentioned 48k as th (grey) and close to a lac for official in India.
