Please suggest av receiver for a 16ft x 17 ft room. Buying from US
siva283
Coimbatore
I am planning to buy a receiver from US and planning to use it with step down transformer. My room size is 16 ft x 17 ft and it is a living room.
My Movie:Music preference is 50:50. My preferences are good sound quality, punchy bass, more power and less problematic than more features.
I am confused between Pioneer vsx-1123 or Yamaha rx-v675. I can get these around $400(my budget). I also like the sound of Harmon Kardon receivers. But trying to avoid it as I am reading in some reviews that HK receivers may have some technical problems. I am also ready to go for a 5.1 receiver but it should have more power to fill my large room.
Which of these would be suitable for me, considering my preferences and my room size?
I am planning to use it in US for next 4 months with a pair of bookshelf speakers and then take it to India. Suggestions for bookshelf speakers are also welcome(budget $250-$300). I would buy Floor standers and other speakers in India.
Siva
Here are some links to get Dual Voltage systems...
Audio Video Receivers | 220volts Audio Video Receivers | 240 volts Aud
Yamaha | Denon | Dual Voltage Audio Video receivers, World Wide voltage 110-220 volt AV Amps
220-Electronics.com | International Relocation Electronics Specialists
When you buy a 110V AVR in US & when you come back to India, you will need to spend an other 3K for the step down transformer...I would suggest you invest in a dual voltage system, which will give you the flexibility of using in US/ India...
Thanks elangoas!
I thought of going for dual voltage initially! But dual voltage sellers have higher price(Yamaha rx-v673 is quoted around $600).. so i feel buying from india is better than buying from them..
so spending 3k on a step down transformer and buying the 110 v should be a cheaper option! can i get good transformers online in india or should i buy it from US
Which of the above receivers would you suggest considering my preferences?
Thanks elangoas!
I think you should combine your speaker budget too with AVR & get a good mid-range AVR....
Yamaha RX-V773 110-240 Volts Receiver 110 - 220 240 volts
I know the 675 sells for around 50K + in india.. So 773series, though older would be even higher in India.. somewhere approx 65K odd...
Denon AVR-2313 220 Volt AV Receiver
The last known price for this AVR is around 75K, though a discontinued model, i think has some good features....
I am not sure, may be if you go there & pick it in the store, may be you would get a fair price....(or) it doesn't work that way in US?
If you still think prices are higher for he dual voltage AVR's, come to india & pick the Pioneer AVR's.. They are the only modestly priced AVR's in India....
Thanks, elangoas!
hv ordered the pioneer vsx-1123 from amazon.... is 1500W step down transformed enough for my receiver or should i go for 2000W?
also thinking whether i can get the transformer locally in india, so that i can have warranty..
Thanks, elangoas!
Congrats on your AVR....Pioneer VSX 1123 is rated around 550W power consumption... So Even a 1000W step down converter should do....There are some well known brands here, but i don't recollect the names...
When you are ready to risk & get the AVR without warranty, why worry abt converter...If you feel the weight would be of disadvantage (Baggage), you can pick them in India...
Hi All
I have brought my receiver to India. Looking for speakers for my receivers. Already have a JBL ES30BK bookshelves for Rear.
Now looking for Front floor standers, Center and Sub. My budget would be 80k to 90k. Please suggest suitable speakers for my Pioneer VSX-1123 receiver. I have Boston Acoustics A360 floor standers in mind. Is this a good choice?
Have purchased a Maxine 1000W stepdown transformer. Would I need a Voltage stabilizer for it or the Transformer would be sufficient? Please advice.
There are some good offers on Boston Acoustics in hfimart.com, Try to get in touch with the hifimart support team & try your luck....
Thanks Elangoas!
I had a chance to listen to Monitor audio M6 yesterday. I liked it. But I felt it to be a little brighter. Does anyone own it? Is it a better choice compared to Boston A360?
The dealer quoted 95k for MA M6 Floor Standers, Center and Sub(not sure of the models of Sub and center). Is this a good price?
Thanks Elangoas!
With which AVR was the the Monitor Audio M6 paired when you took the demo?
