Pls Suggest me 5.1 speaker on budget
techspark
I want to buy new 5.1 speaker set. My requirements are:
1. Simple basic sound
2. Should be wall mountable.
3. I have already done concealed speaker wiring on all walls from electrician so they should be able to connect with that wire.
4. Budget max rs 8000/-
5. Dont mind even if it is 4.1 or 2.1 setup...its imp they are wall mountable and work with concealed wire :)
All inputs welcomed :)
i guess you can get the BA xs 2.1 system for 12k from hifi mart, or else you can go for the sound bar set up with a subwoofer, try philips sound bars, since your budget is limited you can also check some of the locally made speakers if you are lucky you could get a nice sounding system for the price
This would need an amp if I am correct?
Have put used Sony GNZ 8d on sale for 5000. 5.1 DVD system.
If you are from Delhi I can handover. Shipping may cost a bomb I guess :-(
