Pls Suggest Subwoofer for 12 X 18 Ft. Room
slash1814
bangalore
Hi folks,
Pls Suggest the best Subwoofer for 12 X 18 Ft. Room. What should be the best among 8/10/12 inch dia. woofer.
Considering the other components as below :-
AVR :: Yamaha RX-V 471.
Fronts :: Polks RTi A1
Center :: Polk CSi 4
Movie Preference :: I want the Sub to "open up" only when required. No Rumble Boom all the time.
Music Preference :: Tight Bass !!
~Slash
I dont think you can find any sub woofer in that budget which can produce tight and punchy bass for music.
You can check pre-owned if some one is selling.
Velodyne CHT
Rel
Klipsch SW
Polk DSW
Remember all the above are costly. But if you are lucky , you might find a used one.
Make one for less than that.... 12" peerless driver (2800/-) + 300 W Plate Amp (5400/-) + Sealed Cabinet construction using 1" MDF / Plywood (4000/- Max)
