hello guys, searching for a thin flexible hdmi cable in chennai for cheap. Richie street guys have the nylon wrapped chinese makes which are thick and less flexible. Came across a shop where a sony seal packed one was available for 350 bucks. But i was not allowed to check da flexibility since it is seal packed. Is sony making hdmi cables ?. I doubt that...
Cant say i have hunted the entire market. Still there are some shops left. Sometime back i noticed a flat hdmi cable, but dont know exactly how thick it is... Ok...
Now... I need one which is flexible and 1mt in length ( since i have to use wire tie if its lengthy). Will connect it to my wd tv which is kept in a wall mounted shelf.. So if the player is kept close to the wall, it wont cause downward pressure to the hdmi port...
Plz help chennai guys....
Thanx in advance
Thanx in advance
