plz suuggest me cd player model from pioneer and f & r speakers of JBL 4 my wagonr
anup_sel
Pune
Hi fnds,i m havin wagonr lxi duo.I m interested in pioneer and jvc which shold hav frontal usb,ipod suuport..plz suggest me to choose 1 of them..my budget is upto 8k plz mention model no.And i think JBL is good name in audio sys So plz suggest me model no. of that also..
sachin_k5
Re: plz suuggest me cd player model from pioneer and f & r speakers of JBL 4 my wagon
Go for a pioneer head unit and JBL speakers. They will be a good combination.
magma
8k is budget for what exactly?
anup_sel
Pune
my total budget 4 speakers n HU is upto 12k..
magma
12 k budget is for
option1
2 front speakers and HU
or option2
12k rs or all 4speakers ( 2 fronts and 2 back )AND hu
if its option 1
get Pioneer HU 5050 (6.5k-7k) or and 5000 series HU
and Illusion audio components EL 4.1 (5k)
Hermit Audio Pvt. Ltd.
if its option 2
get the pioneer HU 4050 (6k) or the newer 4000 series HU (6k)
front speakers co ax
illuison audio EL42 (3k)
or jbl GT5 402 (less than 2k)
JBL
for rear speakers
if you gonna fit ovals on the rear parcel tray then
JBL GT5 963 (4k)
or ground zero-(its got lovely bass and plays tight)
:: Ground Zero :: speaker systems / GZTF 690MK
about 5.5k
illuison and ground zero products contact ajay kamath at the hermit website
you may use my reference
if you are gonna use 6 inch round speakers on the rear doors and no ovals the you can use
illuison audio EL62 or JBL GT5 652/653
(however you will loose a bit of bass in this option)
