Doomster69
Hi All,
A bit about the user - I'm fairly an amateur when it comes to Hi-Fi, just started exploring online and through auditions. Feel that i have a "decent pair of discerning ears" (bought my AT M50s after some research). Have a very laid back taste in music - Absolutely love my floyd tracks, but listen fondly to reggae, jazz & symphonies, electronic lounge, some hindi (AR Rahman mostly), lots of retro (Led Zep, Who, etc.) & easy rock (Alexis Murdoch). Enjoy warm bass and crisp vocals/acoustics. For video, mostly hi res downloaded movies in the sci-fi (read surround experience) , action (read warm rumbling bass), drama and documentaries (read crisp audio). As i also watch downloaded concerts alot, would love a system with good sound stage.
:sos:What i Need Help On:sos:
Firstly :signthankspin:want to thank everyone on HiFivision forums to make me a more informed person. Thanks to your reviews,discussions & suggestions, my decision set has narrowed down significantly. Keep up the good work:clapping:
Looking for Poor man's luxury
Been saving up for a comprehensive system for 5.1 HT & Stereo listening for quite some time. Till now was managing with my Samsung HT q20 which was received as a gift. The ICB is burnt now thanks to the 3 Ohms speakers being driven at high volume (35-40/50). I stay in a DDA flat in Delhi (read small room 10ft by 8 ft) and may be moving to a larger room house soon (post marriage). Would be sound proofing the room with some dampners (rugs, wall panels, egg crates
Have been saving up for a while to buy some - an affordable luxury system if you will. My budget is between 2 - 2.25 lacs to set up the entire gear comprising AV Receiver, Towers Speakers, Centre, Surrounds and a sub. Though i liked the HTiB from Paradigm & JBL, found these severely lacking from a stereo use perspective. Have been researching a bit (HiFi vision threads, other review forums and personal auditions) & shortlisted the following options for the config:
AV Reciever (50-60K range)
Yamaha - RX V 677
Onkyo - TX NR 636
Denon - AVR X1100
Marantz - NR 1504
(prefer a self calibrating audio set up)
Towers
1st Preference options (Affordable Budget -80-85K)
Paradigm - Monitor 9 - S7 (@Sound Lounge Ghitorni)
PSB - Imagine T 6 (Lakozy)
Monitor Audio - MA RX6
Polk - RT Ai7 (@Pro Fx)
2nd Preference options (Stretch Budget 90-110k)
Paradigm - Monitor 11 - S7
Polk - RT Ai9
KEF- Q900
Klipsch Ref 52
Centers (30-40k)
Polk - CSI A6, CSI A4
Paradigm - Center Monitor 1
PSB - Please suggest
Klipsch - RC-52
Surrounds (30k)
Polk - FX Ai6 or FX Ai4 - (Both Dipole)
Paradigm - Dipole Surrounds (dont remember model)
Klipsch - RS-42
KEF - Please suggest
Subwoofer (35-40k)
90% set on buying SVS PB 1000 - 10" heard good reviews
Would also consider Velodyne Impact 12 or Polk - DSW PRO 660
Klipsch R-10 SW (if Klipsch)
(appreciate warm bass - not the kind u hear in cars with tinted windows in Delhi
Power Amp (pre-out for towers)
- Not sure if i need one?
- do i need an integrated one or a simple power amp will do?
- Which one - model, prices etc.?
Having set the context, have the following queries:
1. Between the AVs mentioned, which one would be recommended - i intend to hook up my hard drive media player, 50" plasma TV, Xbox, blu-ray. Would prefer wireless connectivity - Bluetooth & LAN connectivity. Dont mind a 7.1 & upscaling/passthrough option for future proofing
2. Between the towers, im tending towards PSB T6, followed by Paradigm 9 & Polk Ai 7. Which would meet the wholesome experience requirement? I dont like KEF much - bit warm for my taste. Klipsch audition pending so cant say.
3. Which center & surrounds would you recommend, considering pt 2 above
4. Which AVR would go best with which 5 speaker set up (.1 would most probably be SVS PB 1000)
5. Where can i trim options, considering costs & budget - surrounds or sub maybe?Would the HT experience be complete if i plan to buy the surrounds later, considering the small room. Would i need a sub (for movies) given the room size & the speaker choices (since they have adequate bass)
6. What combinations can i try to limit overspend - maybe look for a lower spec AV & go for better speakers? If so, which combinations (models would be nice)
7. Any alternate suggestions on the center or surrounds? For eg. i liked the center speaker in one the 'Energy' system i auditioned @ pro fx. Was cheaper than Polk.
8. Here is a tricky one - My Samsung HT speakers still work mighty fine, but are 3 ohms speakers. Any "jugaad" for using these - maybe with a decent AV receiver + power amp - can drive these power suckers (till the time i can save up for a bigger budget :lol
In case there are other posts on this, please share. I recall a long post where the gentleman finally bought the PSB's after a long drawn evaluation - can seem to find that thread..
Any help on these would be much appreciated. Greatly indebted to you all!!
Thanks:thumbsup::signthankspin:
Yamaha - RX V 677
Onkyo - TX NR 636
Denon - AVR X1100
Marantz - NR 1504
Towers
Polk - RT Ai9
KEF- Q900
Klipsch Ref 52
Centers (30-40k)
Klipsch - RC-52
Surrounds (30k)
Klipsch - RS-42
Subwoofer (35-40k)
