Pre and Power Amps for Dynaudio Focus 220
Adi30
Kuala Lumpur
Guys,
Would like to have your feedback on the Amp for my Dynaudio Focus 220 speakers. I have Yamaha RXV 3800 from which I am not getting the real output. In addtition to that I have definitive technology centre and bookshelf speakers for the home theatre. Basically I like would ke to use it for music and movies.
Suggestion please as I would like to upgrade my system.
Arvind
Dynaudio needs quality rather than raw power.
Powerful models from Trigon, plinius, odyssey, Mc Cormack could work. Some tube designs also work with Dynaudio. For this, you could look at Ayon.
Dynaudios need power. There is an Adcom set available, which is very powerful, you may want to check it out.
Thanks infact I had audtioned the Dynaudio with Plinius. I was infact looking for AVR to meet my requirement for both Music and Movies. I have Yamaha RX 3800.
rEGARDS
aRVIND
Arvind,
You can try the Marantz AV7005 pre with MM 7055 5ch power amp & add MM7025 2 channel power amp for 7 channel set-up.
Do you have matching centre & surrounds of Dynaudio's??? Subwoofer???
Rgds
