Priority setting
frnd08
India
In convertx there's a setting called the priority level, it can be set from lowest to high, and then to time critical. which one do u use? is there any difference in speed when i select the highest level? and is it recommended?
I use normal setting.
If you set high priority, CPU usage will be high. You can try using this setting if you are not using your PC at the time of conversion. Otherwise other applications could slow down/ hang up.
Learn to experiment, otherwise you will never discover anything new.
hmm. thanks a lot mate. appreciate it.
