Projector power cord
dnshrajn
India
Hello everyone,
I am looking for a power cord to connect my projector. Length should be 10 metres. Any FMs can suggest me anything on this?
I have an Epson HC2040 (bought from US).
TIA,
Dinesh
Hello everyone,
TIA,
Dinesh
30feet is fairly long. Getting a power point fitted would be better than getting an extension cord or a long spike guard. You get these plug n switch boxes in hardware stores. Get one of those along with desired length of power cable with an optional plug point at the other end.
MaSh
Sent from my Redmi Note 3
Yes, the correct solution would be to get a new socket fitted nearby.
You also could buy unterminated power cable of required length and fix a plug and an IEC socket on either end.
