Projector screen ceiling mount options?
s_sachin
Hyderabad
Looking for some advice on how to mount screen to the ceiling. My current screen is mounted to the rear wall using L brackets.
I was suggested mounting to ceiling using wooden strip for support for the hooks. This will save some space and hide nicely under false ceiling.
Anyone mounted screen like this? Please advice
Sent from my Redmi 4 using Tapatalk
Here are step-by-step instructions for mounting a projector screen on the ceiling:
==> Deciding on Screen Placement
==> Decide on the best location for the screen.
==> Attach the mount ::- Ensure that the entire mount is attached to the projector before securing it to the wall/ceiling.
==> Calculate the mount-to-lens distance and adjust throw distance accordingly.
==> Secure the projector.
==> Secure the cables.
==> Adjust the projector settings to fine tune the image. Always follow the manufacturer's instructions.
