Purchasing Component & HDMI cable
tech2010
I want to connect
1. Tata Sky STB's component output with Sony LCD TV's component input,
2. HP laptop's HDMI output with same TV's HDMI input.
So, please suggest brand & model for component video cable & HDMI cable out of the following brands.
MX, Bandridge, Sony, Philips, Panasonic, Monster.
Note:
1. I need good quality cables without spending illogical amount of money.
2. I'm quite OK with separate brand for compent & HDMI cable.
Also, please let me know
1. whether I need to buy good quality audio cable for connecting audio (L & R) slots. If YES, which brand/model?
2. whether Sony PS2/PS3 component cables are compatible to connect Tata Sky STB with Sony LCD TV. If YES, is there any qualitative difference between PS2 and PS3 cables, particularly in my context?
3. good shops in Bangalore to buy those cables from.
Note:
DAC cables from Designer Audio are of good quality, at very reasonable price and they do have a nice range of products.
Always better to go with good quality cables for L&R , again DAC is good enough.
DAC - M.R.P. (w.e.f. September 07, 2009)
READ In this order :Model, Description, Length, Unit, Price including vat
HDMI-1.3C-1.0M, HDMI 1.3C Cable-1M with 1440P Resolution, 1 M, PC, Rs 950.
HDMI-1.3C-2.0M, HDMI 1.3C Cable-2M with 1440P Resolution, 2 M, PC, Rs 1200.
ARX03C, Component Video Cable,2 M,PC , Rs 990
DV8982, Component Video Cable, 2 M,PC, Rs 1200
ARX01A, 2RCA to 2RCA Interconnect Cable,1 M, PC, Rs 1200
ARX04A, 2RCA to 2RCA Interconnect Cable, 1 M, PC, Rs 900
ARA040-1.0M, 2RCA to 2RCA, Interconnect Cable, 1 M ,PC, Rs 450
ARA040-2.0M, 2RCA to 2RCA Interconnect Cable ,2 M ,PC, Rs 650
DEALERS@Bangalore
VECTOR SYSTEMS PVT. LTD. (for Wharfedale, Vanguard, DAC, Byford Audio)
# 97, Sai Brigades, Brigade Road, (After St.Joseph College Of Commerce), Next to Brigade Prince Bar, Bangalore - 25.
Tel: 25543287, 9341717966
TOTAL SOUND (for Wharfedale, Quad, DAC)
# 2, Lakshmi Towers, # 200, R.V. Road,
South End Circle, Bangalore - 4.
Tel: 9845522937
Regards:)
Component cables from DAC,monster,even Philips are good.
MX HDMI cables are cheap & good solution.I got mine for Rs.450, 3mtr
Got mine from ebay from a seller called Cables etc. Two flat HDMI cables of 1.5m each. Price was 650Rs if I remember correctly. Working fine and I doubt any of those astronomically priced ones will give any better picture.
I second that totally ...recently got a DAC ARA040-1.0M, 2RCA to 2RCA, Interconnect and the difference is night and day as compared to my earlier monster cable...the bass is nice and tight, warm treble and crisp highs!
For HDMI look for BlueRigger HDMI cables in Amazon India , you won't find better at 5 times it's price of Rs 320!
