Pvr recording setup help tatasky hd
navigates
I've noticed a behavior with tatasky Pvr; when I schedule a program recording, the recording starts exactly 10 minutes before the program time and ends 10 minutes early too!
Starting early isint so bad as I can forward to the correct point but ending sooner causes loss of recorded time;
Can someone please help guide where is the setting to add time to scheduled recordings please!
I'm not at home any more and this is for my intech savy sister; so pls pls give step by step instructions of how to do it;
Genuinely appreciate Anyones help
Amrit
Okay here it is:
Press Organizer button on remote:
From the menu, select User Settings and then Tata Sky+ Settings
Options avlbl :
Disk Management Mode
Review Buffer depth
Add to start recording
Add to end recording.
The last 2 is what you are looking for.
Enjoy.
Sanjay Thank you sooo much. I'm in the US/LA now. When I reach home tonight, I'll call india and walk my sister through the steps.
Thanks again !!
Sanjay, I tried what you said and no menu comes up; your instructions are for tata sky plus probably;
Can you or someone help with instructions on how to get this menu on tataskyplus HD PVR; this is the new one
Really appreciate your help
Yep.I am talking of TATA SKY HD+ PVR...the new one launched about a week back. Am using one.
What do you mean by "no menu comes up" - pressing organizer button on the remote in any Tata SKY models will open up a menu!!
The steps are:
"Organizer" button on the remote (one of the 4 blue buttons on the top of tata sky remote
A menu come up on the screen with 4 options - help, parental control, user settings and system settings.
Select user settings, then use the down arrow key (just below the select button of the remote) to scroll down for Tata Sky+ settings. There you would get the 4 options as said earlier.
you can view the user guide here - http://www.tataskyplus.com/user-guide-hd.pdf - though it does not contain the menu options screenshots, you would get an idea of the remote.
I have a feeling that she is missing out on the scrolling down - the user settings menu only displays 4 options at a time -to get to TataSky+ setting, she needs to scroll down.
