rdac vs marantz na6005 with b&w684 review
santosh4
Dear frnds,
I have got my MarantzNA6005 yesterday so I did some playback and my review:
1st setup: Good for tight bass and very crisp
bdp170->coaxial->rdac->NAD 375bee->PSB Image t5 & wharfedale sw150
2nd setup: Good for warm bass and very detaild and instrumental no change in vocal
NA6005->NAD 375bee->PSB Image t5 & wharfedale sw150
3rd setup: Not Good at all never mix NAD with B&W
bdp170->coaxial->rdac->NAD 375bee->B&W 684 & wharfedale sw150
4th setup: Good Not punchy but very pleasent
MCR510->B&W 684 & Onkyo THX sub
5th Setup -> Yet to work on it,
NA6005->NAD 375bee->B&w 684 & wharfedale sw150
and note the sub is connected to preout (stereo on my NAD) since sw150 accepts stereo line level input
Guys any suggestion, bottom line is I would sell my rdac.
san
Final Review:
Marantz NA6005->NAD375bee->B&W 684(speker point B) & pre-out of NAD375bee->B&w 610 Sub
Music quality : Absolutely stunning and has a clear minute detail showing up bit by bit, even tried DSD files just brings the life out of system
Marantz NA6005->NAD375bee->PSB Image T5(speker point A) & pre-out of NAD375bee->B&w 610 Sub
Music quality : sounds bright and the audio stage converges but its other way for 684 the sound stage opens up, I feel PSB is good for good tight bass rendering and kind of sharp bass, when I hear the same on 683 its kind of pleasent means bass is little depth than sharp,
Conclusion: i hear lot of vocals like kishore,lata etc and I fee the vocal so clear and clean,
confusion:
should I replace NAD375bee with marantz PM6005? does the combination will be good or can I take it with NAD, kindly suggest
Hope, my review will be helpful for my music lovers :-)
To you my frnd naturelover:
I was wrong, NAD with Marantz sounds good for B&w 684
Rdac with NAD sounds great on PSB
So its all about the Dac and the speaker, I think NAD just does the amplification,
I might be wrong but thats what about my conclusion on hearing them
