Receiver with 2 HDMI outputs.
jackpatel
I plan to install a 42 inch HDTV flat screen & an HDMI projector. I want a receiver which has two HDMI output sockets so that I can connect the receiver to both. Can someone someone suggest a good 7.1 receiver for this setup?
H Patel
Only the more higher end receivers come with two HDMI outs.
You could go the cheaper route and use an HDMI repeater/splitter. Although some people have claimed to have HDCP issues but you could try it atleast if you wanna save money.
Does anyone know the price for a hdmi repeater and a hdmi booster,
heard for the repeater you need to connect power, for booster no power is required and it runs on power from the cable itself, so booster will server the purpose better,
anyone using or having similar products , will be great if you can share the price and performance of the same and recommend which company product to buy ?
