Receiving only pcm signal PC to AVR .. Please HELP
manofx
India
When I watching DTS or ATMOS Original File I am not getting DTS or AC3 Signals from PC To AVR
Note : Tested with PotPlayer , VLC , PowerDVD 21 etc .. (Passthrough HDMI Enabled)
Please help if you are using PotPlayer and you have no issue in passthrough please tell me your potplayer version and if possible export your potplayer settings and share to me here
Thank You
Thank You
Not sure about potplayer, I used MPC-HC and it worked great by enabling bitstreaming.
MaSh
I Fixed it .. This exclusive mode in the attachment should turn on in windows else windows will keep sending pcm output to our receiver always ..
Hope this Solves the issue to someone :)
