Recommendations for AVR+Speakers under Rs.1 Lakh.
soodp
Ahmedabad
Hi all,
I am looking for recommendations for purchasing an AVR and speakers.
My budget is Rs.100000/- for AVR and speakers.
I am buying a Samsung LED TV 32" separately.
I have an old LG DVD 259 player.
The equipment will be installed in the Living Room as I do not have separate room for setup.
On my own, I have zeroed in on DENON 1910 for AVR. The internet price is mentioned at Rs.45000/-. That leaves Rs.55000/- for speakers. I have zeroed in on KEF iQ30 which is listed at Rs.31000/pair. I can postpone buying of the remaining speakers to a later date (within a year).
I will primarily use the setup for playing DVD movies.
Please review my choices for the setup and I am also open for changes in the selection of equipment.
Pawan Sood
Ahmedabad.
Welcome Pawan!
I like the Q series. Nice mellow sound. But since this is for HT, why not get the iQ50. It never hurts to have a decent pair of towers for front channels. Others you can consider are Diamond 9.5 and BR5. Hope this helps.
Cheers.
Two others have opened a similar thread (AVR + Speakers = 100k).
Please go through them as they will give you options.
http://www.hifivision.com/what-shou...it-budget-avr-speakers-sub-please-advise.html
http://www.hifivision.com/home-theater-box/5963-hometheatre.html#post73117
Denon 1910 is an allrounder for music and video. You should be able to get it for 40k (10% off MRP). You can also check out Marantz 6003 available for 42k.
Raghav
Hi all,
Pawan Sood
Ahmedabad.
I'd look at the KEF KHT2005.2 set as well. I picked up the 1909+KEF from ProFX in February for 99k.
Hi all,
Pawan Sood
Ahmedabad.
Hey Pawan
Denon - 1910 is somehow a hot selling product, and is seriously worth...
In for speakers, i can recommend you the Q Acoustics speaker package, in total the complete 5.1 Package costs Rs.58000...
After Discount, including cables, etc, you can get Denon1910 + Q Acoustics 5.1 + Cables(50mtrs) = Rs.98,750
Hey Pawan
Correction: Price for Denon 1910 after discount and with Bill and Indian Warranty RS.36.5K for Q Acostics Package discounted Price Rs. 45K. Cable 50 meters DAC 12 AWG 5K. Total:86.5k
I recommend a Onkyo TX-SR606. Very good specifications not just on power but on features as well. I have listenend to this receiver paired with Polk Audio & its a good match.
You can buy this receiver & walk into Pro Fx and try it with the Polk Rti or Tsi Series. One of series should suit your taste.
I won't buy a Polk Sub & you can do much better with a Sonodyne/Wharfedale Sub Woofer.
i'm from kolkata and i have got a quote for denon1910 + Q acoustics 1010i package + pioneer dv-610 dvd player + cables + wall-mount brackets fro fronts/surrounds total for 105k. what is the opinion of all members regarding this pricing.
regards,
Piyush.
regards,
Piyush.
You could save another 10k here, as the break up seems to be like:
Denon 1910 around 36.5K
Q Acostics Package: 45K
Pioneer Dvd : 6 K
Cables Max: 5 K
Bracket Max: 2K
Hi all.
I have settled for Denon AVR-1910 and a pair of KEF iQ50.
Discounts @10% off MRP offered by ProFX dealer in Ahmedabad.
I did audition Wharfedale 9.6 and the quote I got was Rs.41000/pair.
I was inclined for the KHT2005.3 but budget was not permitting :sad:
Thanks to all who responded.
-Pawan
Pawan, how the KEf IQ5? Did you hear the other series too - IQ 7 & 9.
What did you find good in them? Vocal clarity? Bass..?
The dealer in Ahmedabad had iQ90 which I auditioned with stereo music output with DENON and also BD movies played through Sony Playstation and projector in Surround Sound. Liked the vocal clarity. For iQ50 I have gone with the reviews on net.
